PROGRESS M-01M DOCKING
Hans
Beitrag von Hans »
Problemen:
Nine minutes later, the Progress reached orbit and deployed its solar arrays. One of several antennas associated with the Kurs automated rendezvous system apparently did not deploy. The Progress passed out of range of Russian ground stations before all of the data from the initial post-insertion analysis could be received.
Russian flight controllers will review data in the hours ahead and determine whether any troubleshooting may be required. The antenna in question is one of two so-called "narrow field proximity antennas" used for range and range rate updates to the Progress computers through the final stage of its approach for docking at the Pirs Docking Compartment.
Weiteren info: http://www.nasa.gov/mission_pages/stati ... index.html
Viele Grüße,
Hans (Niederlande)
Re: PROGRESS M-01M DOCKING
Jetzt zum Überflug starke Signale auf 166 MHz PCM und 922 MHz Beacon von der Progress M-01M.
Hier steht auch noch was darüber. http://www.spaceflightnow.com/shuttle/s ... ndex2.html
Jup, gleiches hier. PCM auf 166 Mhz. war mächtig stark.
